12-21-2023
06:01 PM
06:31 PM
SamanthaW
I have a Lide 300 with and I can´t configure the Copy Button to work with a Network Printer.
In the configuration of the Canon App for Windows, the Network Printer is not listed.
The only Printers shown on the list are
One Note
Microsoft XPS Document Writer
Microsoft Print to PDF
FAX
The IJ Scan Utility Version is UNKNOW as I can´t figure out where to find it and check if there is an Update. But the file name is win-lide300-1_1-n_mcd.exe
Regards,
Martin
12-27-2023 02:22 PM
I recommend you reach out to Canon support. Our team will be able to assist you in real time with this matter. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
