09-16-2024
03:56 PM
08:47 AM
Hello, I've just purchased an XF605 camcorder and I edit footage in Final Cut Pro - I need help with two things. First, my practice has been to import my video clips for a project into stand alone folders, outside the Final Cut Pro video library. Then in the library for that project, link to the clips in the folder I created.
I've been using a Sony camcorder and their import tool, Catalyst Browse, makes this simple. I just select the clips I want and it transcodes them into Apple ProRes files, without extra metadata files. I tried the Canon XU app for this and found that some of the clips, I believe those formatted XF-AVC, get trascoded into multiple files - a .mxf, a thm, a .xml and a .mif. I'm think the .mxf is the video and audio -- is it all I would need to import into Final Cut Pro, or would the other files be necessary?
(I understand that Final Cut Pro will transcode the clips but it puts them into a library file, so I'd have to copy them out to a stand-alone file, then delete what's in the library in order to have the small library file I'd prefer. Plus, I reuse clips between different projects, so I'd like to avoid having several libraries that are using aliases of clips copied from other libraries.)
The second question I have is about metadata showing recording format information. Neither method of capture I tried, (Final Cut Pro capture or the Canon XU app), seems to show the original recording format information in the metadata, (ie: XF-AVC, (MP4(HEVC), MP4(H.264). I'd like to know that information about the test clips I recorded so I can compare them - does anyone know how I find that information?
Thanks for any insight on this.
