09-14-2024 02:05 PM
So I have a new to me XA60 and it says I can shoot 24fps and 30fps in 4K BUT when I have it set to 4K resolution the frame rate option is grayed out and not possible!?!?
anyone of help here? Manual isn’t helping sadly or I plum missed it.
09-16-2024 06:41 PM
Hello Tynimiller86,
Let's check that the USB mode is not set to [UVC Video Output (UVC)]. Recording settings cannot be changed in this case. You may also want to check what shooting mode you are set for. Some modes will limit certain settings. Let's set the camcorder to the [P] mode and try again.
09-16-2024 07:41 PM
Got the USB mode switched, still not allowing. Searched came up empty for [P] mode anywhere?
09-16-2024 07:59 PM
Found it, tried all the various settings from Portait, Sport, Low Light, Fireworks I believe all of them and none when I went back into FPS could change.
