10-19-2023
08:14 PM
09:06 AM
I have the same problem, my canon AX10 "Control for HDMI" and "HDMI 1080p" are ON but they are blinking. I have tested multiple HDMI cables.
My camera is connected to Hollyland MARS 300 PRO transmitter that always it work correctly with it. I have connected to TV instead transmitter and is the same problem. I have oppened camera and PCB looks good. When I disconnect devices, HDMI menu's option stop blinking.
10-21-2023 05:41 PM
Greetings FisiClay,
The blinking in the HDMI menu refers to a signal issue. Test an HDMI cable, about 3 - 10 feet long, and connected to a display. This will help to determine if the issue is with the HDMI terminal. We recommend on testing a couple of cables.
If the issue persists, then the issue may be caused by an internal component of the camcorder. I understand you state you have inspected the PCB but we would recommend on sending the unit to our facility for service.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
