02-23-2014
02:14 PM
10:39 AM
Does anyone know where to download C100 Data Import Utility for C100? I just bought a used c100 that did not come with the disc and hoping to find out how to order a new one or if there is a download somewhere. Anybody out there think this is a must or can bypass with something like clipwrapper?
02-26-2014 07:55 AM
Hi corbyn!
Thanks for posting.
The Data Import Utility is made and provided by Pixela. You can download it from their website. Please refer to the link below:
http://www.pixela.co.jp/oem/canon/e/dataimportutility/download.html
02-26-2014 06:43 PM
Thanks Mike!!
Is there a Mac Version available?
06-19-2014 12:36 PM
06-19-2014 01:29 PM
Hi everyone!
Since Pixela is the maker of the Import Utility, you'd want to contact them to see about obtaining a replacement disc. Here in the US, their number is 800-458-4029. If you need to reach them from outside of the US, you'll want to contact Canon Support in your area by going to www.canon.com and selecting your region/country to see what number to use to contact Pixela.
Bear in mind, you don't have to use the Pixela software, there are many other third party options out there like Sony Vegas, or Adobe Premier Pro that will also work (only to name two; but many others will work just as well, and we don't prefer any one over the other).
We hope that helps!
06-19-2014 04:28 PM
I have Sony Vegas Pro which works but leaves a gap of missing video and audio between the cards when recording in relay.
As a long time Sony EX shooter it seems crazy that we have to go chasing around for software like this when others provide DL links??
Steve
06-19-2014 04:34 PM
Hi Steve,
You will want to contact Canon support in your area.
The Canon Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click here and select your country or region for your support needs.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
06-23-2014 12:29 PM
I'm on a Mac as well, but I'm wondering what situations need an import utiliity? Why not just use the editor nle import function? I use both FCPX import and Adobe Prelude (both make a copy of the video files and optimized versions as needed).
09-14-2014 05:23 AM
So I found a simple work around. I was having dificualty only downloading the VIDEO files, with no AUDIO becuase they are stored in 2 separt folders when recorded to the SD card from the c100. All you need to do is
sd > card reader > computer > [open folder via my computer]
EOS CANON C100 > PRIVATE > AVCHD > BDMV > STREAM (video files)
> CLIPINF (enables audio files to be interpreted in NLE's)
****STREAM (contains video file copy them to a new folder on your hard drive. Then the tricky part, also open the folder CLIPINF this folder holds files with the extension .CPI select all those and copy into the same folder you created for the video files. Then simply import the video files into a NLE's such as Premier Pro then your good to go!
Took me about an hour of frustration then I went back and just opened all the folders. Trial and error = Knowledge!
Enjoy hope this helps
03-29-2016 02:43 PM
This is a little late but I figured I'd mention this in case someone else has the same problem I did. If you go to the pixela homepage and select professional camcorders you should see ver 1, 2, & 2.3 listed for different c100 makes. If you click on either of the "download" links under the quick menu you'll be taken to the update-only downloads. But if you click the "software" link under the quick menu you'll be taken to a page where you can enter the serial number of your C100 and download the complete data import utility. Should work for all C100 models.
