Rookie Question - Canon C200 OSD
jongraphs
Hey everyone,
Rookie question. I managed to get all the OSDs to not show on the canon c200. Now I can't get them to show again, and no menu shows up when I hit the menu button.
Any ideas? Tried literally every button... is there a combination of buttons or a shortcut, or even a reset, that will get them back?
Thanks.
jongraphs
Solution:
Toggle to playback (Media) mode, then hit the menu button and OSDs will show.
From there, go to "Monitoring Setup" and look for OSD Output, turn on.
This truly was a rookie question.
4 REPLIES 4
jongraphs
Bump
Hi, jongraphs!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
Thanks and have a great day!
jongraphs
Thanks. I tried the self-service resources. I’ll just give you a call on Monday.
jongraphs
Solution:
