06-17-2023 11:27 AM
After updating to firmware 1.0.3, camera no longer draws power over USB. When connected, via the same source I was using before, camera would draw about 5 watts of power. Now it draws none. However, the camera shows it’s in USB PD mode, but battery still drains as if not plugged in. I checked and made sure the USB option was not on video out mode. Any suggestions?? I’m worried that the USB port might have failed somehow or the firmware update isn’t allowing it charge and power over USB PD.
08-17-2023 04:30 AM - edited 08-17-2023 04:31 AM
I was in contact with canon for about 4 weeks back and forth and the only thing they said is that it only is supposed to work with the official power adapters. That's it. I'm stuck now with 10k worth of cameras :(((( best customer support o.O
08-17-2023 10:08 AM
I believe the real issue here is your body needs service. There are enough ways to test USB-PD without using the Anker Power Bank, which is much less expensive now than when the R5 C was released. If you test with 2 different sources and the PD fails, I recommend getting the body to Canon. While this is not something we look forward to, it happens. You get the issue addressed and move forward. I'm very sorry you are going through it now. I don't use my camera professionally but would be disappointed if I couldn't use it the way I wanted, or it was intended. Get it inspected so you can continue enjoying it.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
08-17-2023
10:31 AM
10:33 AM
Thx for your response. How else should I test it? I tested 2 different R5C Bodies with 2 different FX Lion V-Mount Batteries and 2 different Anker USB PD Chargers and a couple of cables? The problem is I proposed to bring my camera to a service center, but they refused to check it!
[Ticket number removed to protect privacy.]
08-17-2023 11:39 AM - edited 08-17-2023 11:40 AM
I don't understand why they won't inspect your camera(s). You are presenting for service.
"Hi, my camera is not charging or being powered through USB-C PD. Can you please tell me why not"?
They take it, run diagnostics and will probably tell you the main board needs to be replaced.
They were purchased in the country where you are trying to get service correct?
08-19-2023 03:27 AM
Yes, of course. I try another time to write them.
10-01-2023 02:15 AM
I've had the same issue regarding powering by PD - it draws nearly nothing from PD and just runs down the internal battery. Mine is only a few months old and I've hardly used it. Have you had any resolution to this issue?
10-05-2023 11:33 AM
Hi Michael, unfortunately I just tested the official power solution from Canon, the USB-PD-E1 Adapter like I was told from Canon. They said it will work 100%. But unfortunately, the internal battery still drained completely. So both my cameras are 100% defective. I will talk to Canon now and bring them to service.
11-29-2023 12:34 PM
So almost half a year has passed talking back and forth and now I have an answer from canon service. turns out there was a surge damage to both cameras. I now need to pay 450 euro to get them repaired. Only thing I did was to power them via USB-C with an FXLion nano two battery which even canon uses in some of their official videos on their youtube channel. Maybe I get them repaired and as soon as I plug my FXlion in again both will be fried again.The camera is not usable without an vmount!
03-07-2024 11:49 AM
Long story short I got both cameras repaired by canon and the exchanged the powerboard... Just so u guys know.
03-20-2024 03:53 PM
Well shoot. Looks like I’ve got to start this process as well. Thanks for your info on that journey. Mine’s malfunctioning the same way. I’ll start a new thread and contact Canon.
