06-16-2025 12:14 PM
Hi all. I bought this camera new from Best Buy back in March of this year. It's for church use, and so gets between 4-5 hours a week of use. I came in last night to find the screen was orange. I remove and reattached the battery, and now the camera won't power on or show that it is even charging. Before I take it back and get it replaced, is there anything the community recommends? Thank you.
06-18-2025 05:24 PM
Greetings Serenayde,
Try checking to see if the camcorder powers on with the memory card removed, and to remove any additional accessory that may be attached to the camcorder. Please also check to ensure there is no debris on the contacts of the battery pack and on the pins where the battery pack mounts to.
If the issue persists to where the camcorder is not powering on, then we would suggest sending the camcorder to our facility for repair.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
