02-03-2017 07:27 PM
The "Wireless Controller WL-D88" that came with my Canon FS-11 works (sometimes) in starting a video recording, but it never works to stop the recording.
I installed a fresh battery (CR2025) but the "Start/Stop" button only occasionally starts a recording, no matter how closely I stand near the camcorder. I do point the remote control directly at the camcorder. I see a "set" button on the remote. Is there a setting to make the device work?
02-05-2017 12:07 AM
Hi Djard,
Thank you for posting.
From your description, it sounds like your DL-88 may require replacement. To check for availability, I recommend contacting our Sales and Accessories Department. For contact options, please click here.
02-05-2017 02:44 AM
02-05-2017 10:09 PM
Hello Djard,
The wireless remote may not work properly when the remote sensor (which is on the side of the LCD panel) is situated under bright lighting or the sun.
If the wireless remote doesn't work check in the menu that [WL. REMOTE] is not set to [OFF].
I know you mentioned changing the battery but I would definitely check this again just to be sure that it's a) a good battery and b) inserted corrected.
