09-16-2025
05:03 PM
09:07 AM
I have tried all videos and all related threads on here, none of the solutions have worked for me.
I recently got an R5C with firmware 1.1.0.1 trying to update to 1.1.1.1.
NOTHING HAS WORKED. The steps I have taken so far:
Battery at full charge (LP-E6NH), Reformatted SD to the camera, removed CF card, Removed lens, file is in root directory of SD card. I've tried it all and the text is still grayed out.
Please help!
09-16-2025 07:03 PM - edited 09-16-2025 07:05 PM
Wow. That's some original stock you got there. That's the (shipping) firmware mine came with back in 2022.
Sounds like you're doing everything correctly. You are aware that you have to upgrade firmware on this device in Cinema OS. You cannot do it in photo mode. To navigate, you will use the quick control dial to move the cursor and select OK then press set. The firmware upgrade will take approximately 9 minutes. Do not touch any of the buttons during the upgrade process. You will be notified when it completes.
If you are still experiencing difficulties. Reply and we will dig into this deeper.
09-17-2025 04:31 AM
Just to add a couple of points:
Hope this helps..
