07-25-2023 12:57 PM - edited 07-25-2023 04:27 PM
We have manually setup an IPV4 address on the camera and additionally disabled IPV6. All computers and cameras are on the same subnet. We can ping the IPV4 ip address just fine. When trying to access the camera via the IPV4 IP address in a web browser we get a 403 Forbidden message in the browser. We have tried multiple browsers and cleared caches and such. Please advise.
07-27-2023 06:55 PM
Hi ChillySoft,
I'm sorry to hear your CR-N300 is not getting an ipv4 address. To trouble shoot this issue you will need to call the phone support team. The CR-N300 phone support team can be reached at 1-800-652-2666 from 8 a.m. to 8 p.m. Eastern time Monday through Friday.
07-27-2023 09:17 PM
It sounds like you might have misconfigured something on the camera's webserver. 403 is typical of a permissions error on the server side. I'd reset the camera and try again. IPv6 can cause connectivity issues occasionally but is likely to be ignored otherwise. What application did you use to configure the camera?
If this is a new camera, there is no reason not to contact support for set up and configuration assistance as Hazel_T suggests.
07-28-2023 03:24 AM
We used the CameraTool to discover the camera itself. Connected to the camera via web browser, disabled IPV6 and statically assigned an IPV4 address. That's it. No DHCP or internet connectivity on the network we are using. Pretty basic and I am a network guy.
