10-28-2023 04:20 PM
I borrowed a friend's C70 and the display turns black after its been flipped and I press it make it flush with the back of the camera. The monitor works while flipped, it turns black when pressed inward. I have a C70 and this hasn't happened to me before. I checked the menu and didn't see any options that would cause it to happen.
10-30-2023 12:59 PM
Hello nickkasimatis,
You are correct in that there really is no menu setting that should cause this particular issue that you are experiencing. With that said, I would still recommend resetting the camera to factory default settings to start. This is found in the System Setup (wrench) menu. You may use a dry microfiber cleaning cloth to wipe the battery contacts. Also make sure that you are using genuine Canon batteries and/or the Canon power adapter. If the issue persists, then the camera should be evaluated at a Canon factory service center.
10-30-2023 12:59 PM
10-30-2023 01:12 PM
Thank you, I have done some tests and the problem persists. I’m going send it in for repair.
