C100 Mark ii HDMI output only 480 - can't get 1080
MV0925
I am trying to connect a Elvid FieldVision 10.1" monitor via HDMI for a small director's monitor and no matter what I do, I am only able to get a 480 signal from the HDMI output.  I can get 1080 when the monitor is hooked up to my 5D mark iv and I have played around with HDMI cables, and camera settings but nothing works.
10 REPLIES 10
rs-eos
What specific codec are you using on the C100? On page 135 of the User Manual, it shows that the HDMI output signal will be 480 when recording in low bitrates for both AVCHD and MP4.
Ricky
MV0925
I am recording AVHD 24 Mbps LPCM at 23.98p
IamintheUK
Rising Star
Rising Star
The HDMI output is interlaced so is outputting 1080i. Your monitor either needs to be capable of playing interlaced footage, or apply a pulldown to give you progressive playback. That 480 is the resolution of a single field.
__________________________________________________________________________________________
EOS C100 mk2 with a Canon EF-S 18-135mm IS STM, and a Sigma EF mount 10mm-20mm EX DC HSM wide angle - Zoom H2Essential - Dell 8700 i7-4790 3.6Ghz, 24GB Ram, Win 10, Nvidia GTX 1060 6GB - DaVinci Resolve Studio 20.3 - Blackmagic Speed Editor - Presonus Faderport 1.
I'm not following.  480 would be for SD (standard definition).  And wouldn't a single interlaced frame for 1080p contain 540 lines?
Ricky
IamintheUK
Rising Star
Rising Star
You will get 480 if the camera is set to 60Hz. For 50Hz you will get 576. The OP needs to check his setting on the camera. To get a 23.98 frame rate at 1080p the monitor, if it doesn't display interlaced footage, will need to apply a 3:2 pulldown.
How do you apply a 3:2 pulldown?
IamintheUK
Rising Star
Rising Star
You would need either a hardware device that is capable of doing it like a monitor that will play interlaced or progressive footage, or a recorder such as one from the Atomos range, or an NLE such as Premiere Pro or DaVinci Resolve. Possibly a mini converter from Blackmagic Design may be able to do it.
I just heard back from Elvid costumer service and apparently the monitor can handle interlaced footage so I'm at a loss. Could there be a camera setting I am missing?
That's where I'm stumped as well since the Elvid specs show that it should indeed support that particular HDMI signal your camera is sending out.
Long shot here, but do you have a TV or AV receiver that would provide displayable info about an HDMI input signal?  Wondering if that could help determine just what type of signal is being output.
Maybe also try different frame rates just to see what would happen.  e.g. 29.97.  Any difference?
Ricky
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
