07-07-2024
11:41 AM
10:40 AM
I have canon prograf 300 printer. I am using Kodak ultra premium paper. After printing I see the dark black side has some smudges or I would say the print is not properly drying only on the black side. I am using glossy paper and glossy paper setting under professional print and layout.
This occurs only if I use highest quality setting. In standard quality the print is proper
07-08-2024 06:38 AM
Google “order custom printer ICC profile” and you can select a company.
You would print a special pattern print and mail it to the company. They create the profile and email it to you.
07-07-2024 12:14 PM
I do not believe a paper profile for Kodak ultra premium exists. Have you considered using papers (canon or others) which have a supported profile?
If these are truly smudges, you can change the ink drying time in settings.
Canon : imagePROGRAF Manuals : PRO-300 series : Advanced Paper Settings
I'm not sure this is the problem here however. The black patches do not appear to be smudges.
07-07-2024 04:00 PM
I stay in India. It is very difficult to get canon paper. The premium paper available are from Kodak. Hence supported profile I cannot use.
07-07-2024 07:34 PM
When you use the Standard print quality setting you said that the black problem does not occur.
How does the rest of the print look?
07-08-2024 12:10 AM
Rest of the print is good but not excellent. Earlier I was using Epson printer which has 6 cartridges and with the highest quality setting, the print is better than the Standard quality of canon printer.
07-08-2024 06:07 AM
If you have a lot of that paper then maybe you want to have a custom printer profile created.
07-08-2024 06:21 AM
How to create custom printer profile?
07-08-2024 06:38 AM
