11-07-2024 01:32 AM - edited 11-07-2024 10:46 PM
Hi, I notice there's almost a tapping / clicking noise when the printer is printing (included video here). I wonder if this is normal? Just bought the printer earlier today, trying to figure out if it's a defective unit...
11-07-2024 08:21 AM - edited 11-07-2024 08:25 AM
Hey there!
Welcome to the Canon Community! We’re excited to have you here, and congratulations on your new #TeamCanon gear!
Just a quick note: I removed the link from your post to keep everyone safe since we can’t verify the file type. No worries, though! You can easily re-share your video using a service like YouTube, and even embed it in your post!
Thanks for understanding! 😊
P.S.
The Community isn't intended for immediate assistance. If your question is urgent, click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE for support options.
11-07-2024 10:47 PM
Thanks Stephen, I've shared the video via YouTube.
11-11-2024 05:30 PM
Hi themagiceight,
Because this issue is hardware related, it is recommended that you contact one of Canon's Technical Support Representatives via phone or chat. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your product and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support. A Technical Support Representative can determine the cause of the issue and resolve it or provide you with your available service options.
11-11-2024 05:48 PM
Hi Patrick, so you would say that the sound in the video I posted isn’t normal?
11-11-2024 08:27 PM
I believe that is just the sound the print head makes as it travels back and forth across the paper spraying ink.
08-28-2025 01:18 PM - edited 08-28-2025 01:23 PM
Hi, themagiceight. I hope you're doing well.
I'm having this same issue, and I just got the printer. It's doing this right out of the box. I noticed that the click can vary in volume, even approaching more of a knocking noise, and it's always at roughly the halfway point of the print head's travel back to the right from the left. I used a flashlight to see where the print head is when the sound occurs, and that's the exact spot every time. Is that where yours is doing it too? I haven't heard this issue in anyone else's videos I've seen on YouTube and elsewhere, so I can say with confidence that it's not normal. The big question is whether it's a sign of something wrong that will cause premature failure of the printer (like, right after the warranty runs out lol).
I tried to chat with customer support, but they told me I would have to call and let them listen to the printer in action. Their hours of operation are the same as my work schedule, so I can't do this, as the printer is at my house, not at the office. I was told this would be the only option before they will consider any support for it, even though I offered to provide a recording I made of the sound when I first encountered it. So, I'm not sure I can depend on Canon for help at this point. If someone else has experienced this issue with the printer, hopefully they'll come across your post and offer insight into a possible fix.
09-08-2025 03:11 PM
I'm curious, do you get the same sounds with larger paper of the same weight? I'm getting similar sounds with 5x7 paper which looks like what you are using from the video. But when I try the same exact paper from the same vendor but at 11x17, there's no banging sound. Makes me wonder if the larger surface area from the larger paper makes it easier to pull down with the paper-handling vacuum system.
09-08-2025 03:32 PM - edited 09-08-2025 03:32 PM
I've had to RMA this printer twice at this point (due to unrelated horizontal banding), and both replacements do the exact same thing. Not sure what causes the noise, but it appears to be normal. I had the same observation though — it only occurs on smaller sizes.
09-08-2025 04:47 PM - edited 09-08-2025 04:47 PM
Hi, eceforge. I'm having it with every type of paper, every print setting, and every size. It is always on the print head's return to the starting position (moving from left to right), almost exactly halfway across the width of the printer as it moves that direction. Sometimes it's quiet like a small click (particularly when the print head is moving slowly), and sometimes it's more like a knock (when it's moving fast). My hunch is that it's not supposed to do this and that it is indicative of something that's going to wear out/break prematurely.
