12-16-2022
01:59 PM
02:07 PM
Can someone tell me what settings to use so I can print on 16x20 paper on the pro-1000. Any advice would be greatly appreciated.
Thank You in advance.
12-16-2022 05:42 PM
Are you using a fine art paper. Typically they need to be fed from the manual feed tray. Fine Art papers have a minimum margin default. I think there is a way to override that on the Pro-1000 but I’m not sure. For the Pro-100 there is a 30mm margin as a default to avoid head strike smudging.
12-16-2022 02:07 PM
I would assume it is the same as my Pro-100.
1. select Custom at the bottom of the page size dropdown.
2. Input 16 and 20.
12-16-2022 05:32 PM
Thank you for your response. I changed it in the printer setup but I get a message that it is not capable with the paper in the top feeder. I need to know how to override the margin error setting. I should have stated my question better.
12-16-2022 05:42 PM
12-17-2022 08:11 AM
Great Thanks for the info.
