09-21-2019 07:35 AM
How do I reset the web access password?
Can I disable auto nozzle check?
09-23-2019 04:04 PM
Hello.
The default administrator password should be the serial number for the unit. If you cannot recall the password, you will have to reset all of the settings. Details on how to locate the reset option can be found at the following link:
PRO-1000 Online Manual - Reset setting
Details on how to disable the Auto nozzle check setting from the operation panel of the printer can be found at the following link:
PRO-1000 Online Manual - Auto maintenance settings
