Reply
Highlighted
New Contributor
Accepted Solution
Trouble aligning print head
I just got a new Pro-100 and while trying to allign the print head I keep getting a message that says the rear tray is open and it needs to be closed.  It is closed.  Any help would be appreciated.
Highlighted
Occasional Contributor
Re: Trouble aligning print head
There's a long rectangular flat dark gray piece at the rear of the top, just in front of where you load the paper, that flips forward when you're loading paper, but you after you load the paper, you have to flip it back. It sort of covers most of the opening where the paper feeds in from the back tray. If that piece is flipped forward it won't print. Does that help?
Neil
Indigo Image Lab, Inc.
Highlighted
Hi imgmkr,
You will want to make sure the feed slot cover is closed. Please see the picture below for reference.
Highlighted
New Contributor
That solved my issue. Thanks!
powered by Lithium
