06-15-2014 10:26 PM - edited 06-15-2014 11:36 PM
I printed using front load (13x19 sheet) on my last print job. I changed just now to using 8.5x11 (after the printer was shut off) and now it's stuck in front load mode and will not print (unless I printed from front load which makes no sense to do).
Is there a setting I need to change to get it back to normal printing? Getting it into front load is done using the buttons on the front of the printer. Nothing is lit up now except the power button. The bottom tray is down in normal printing mode. The back tray is up.
I opened Print Setting > Quality & Media > Paper Source > change to Rear Tray and hit Save. It doesn't take. I hit Print (Lightroom Print Module) and print queue still says it wants to print from the front tray. When I go back to Print Settings to check the Paper Source it again reads Rear Tray.
Thanks for your help!
Terry
06-18-2014 10:37 AM
What system are you using? You may need to delete your print spooler (Win). You also need to turn off the printer for some time, overnight, perhaps. Reboot the computer. Turn the printer on.
06-23-2014 09:07 AM
MAC Mavericks
This happened after it's been off for some time already. The last print job I did was from the front tray.
I will try rebooting. It's probably been rebooted since the last print job but I'll give it another go.
Thanks.
Terry
