01-09-2020 01:56 PM
Hello. I just installed my PIXMA Pro 100.
Can I print images onto black paper?
01-09-2020 03:02 PM
The Pro-100 is a dye ink printer; ink is absorbed into the paper. I doubt you will get anything worth looking at.
02-04-2020 10:17 PM
Even a pigment ink printer isn't going to print on black paper. You would need white ink. T-shirt printers, for example, lay down white ink first when printjng on black, then lay colored ink down over that. Even silk screening on black first requires a pass with white, then colored ink is screened over it. And lastly, as an artist I can tell you that painting with guoache, acrylic or oil on black gessoed material also requires a layer of white before color. There's just no way around it.
@jrhoffman75 wrote:The Pro-100 is a dye ink printer; ink is absorbed into the paper. I doubt you will get anything worth looking at.
