Reply
New Contributor
Print Studio crashing from Photoshop (Catalina)
I am running Photoshop CC (version 20.0.6), and on a Mac Mini macOS Catalina 10.15, which I recently updated. When I attempt to load Canon Print Studio Pro from the Automate menu, the plug in begins to load, and then reports and error and exits.
This did not happen prior to the Catalina upgrade.
Anyone else having this problem?
Esteemed Contributor
Re: Print Studio crashing from Photoshop (Catalina)
[ Edited ]
What printer model do you have?
PIXMA PRO-10
PIXMA PRO-1
PIXMA PRO-100
PROGRAF PRO-1000
What version of Print Studio Pro are you using?
v2.2.3 is only certified for Mojave thus far.
~6D2(v1.1.0) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 2080 FTW3 Ultra ~Pixma Pro-100 ~ImageClass MF644Cdw ~LBP622dw
New Contributor
Same thing happens to me when I try to print. What can we do?
VIP
I suspect you need to wait for a new version of PSP that is compatible with Catalina.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
New Contributor
The same thing happened to me. The reasons for this are apparently the annoying new security provisions introduced with Catalina.
I was able to sove the problem by manually adding Print Studio Pro (and the other Canon Utilities) to have full disk access.
Go to Apple Menu -> System Preferences -> Security & Privacy, click on the Privacy Tab and scroll down to Full Disk Access and select it.
Click on the lock Button and enter your admin credentials, then click on the "+" button and locate Print Studio Pro (should be in the Canon Utilities within the Applications folder).
See attached screen shot.
Now Print Studio Pro should open up as usual.
Please note, however, that printing with Catalina is NOT flawless, I get "Communication Errors" from the print driver quote often.
Hope this helps,
WhiBal
New Contributor
Thanks, whibal:
This worked for me, both my pro-1000 and pro-100.  Only problem left is that it will not recognize the manual feed--tells me no paper in the top feed--when I move a sheet to the top it prints normally.  Any additional suggestion.  I have updated both the printer driver for the 1000 and the newest version of PSP.
Occasional Contributor
It seems like there are a lot of bugs currently with Catalina and Canon printers. Apparently there is also an issue with the printer not remembering the paper selection under the new driver; see the following forum link for more information:
https://community.usa.canon.com/t5/Professional-Photo-Printers/Pro-10-Printing-Issue-with-Catalina/m...
Canon, please acknowledge that you are working on a fix for this!!
Hope this helps,
WhiBal
Thanks for your post whibal. I use PSP to print from LR in my workflow and its very frustrating the PSP has stopped working after I upgraded to Catalina. I've been trying to implement your workaround but have run into a problem. I can see and add the Canon Calibration Tool, the Canon IJ Network Tool etc. but there is no application to add in the Print Studio Pro sub folder under the Canon Utilities folder. Any help would be greatly appreciated.
silvasolve
VIP
Welcome to the forum silvasolve.
Did you download the PSP installer from the Canon support site?
Hello John, thanks for responding. Yes, I did download it from the Canon Support Site.
Regards
silvasolve
powered by Lithium
