Print Studio Pro
regmikewall
Enthusiast
Besides adobe PS, LR or PSE, what other photo applications can use Print Studio Pro.  I use On1, Luminar, & Aurora?
Thanks in advance for your help
Mike
15 REPLIES 15
Preview will automatically select the correct Canon paper profile based on the selected Canon paper type. (I am assuming you have the IJ series printer driver installed and not the Bonjour-Airprint driver).
See attached snapshot:
Select paper in Presets. Select Color Sync in Color Matching and you will get Automatic. If you were using a third party paper that said select Canon Platinum media type you would select that Preset and the third party ICC profile.
But you can also load the Canon ICC profiles and selct them as well.
If you were to select Canon Color Matching everything happens behind the scenes.
My print screen is different from your, see attached Capto_Capture 2018-10-20_05-23-21_PM.png
Also, I am not very savy about print drivers, how do I determine which driver I have installed?  Sorry to be such a dunce.
Mike
What software is that from?
What version maxOS?
What screen apears when you slect "Print Setup"?
On1 Photo Raw 2018.5
OS 10.13 - High Sierra
The one I attached
Your posted screen is Print Settings. Print Setup radio button is in top right. I am betting that screen will have you choose a media type. You are set up to have printer manage, so the driver will select the correct ICC profile,
There is nothing wrong with treating the profiles I sent you as third party and selecting tem as you would a third party paper, but it isn't necessary. The macOS system will do it as well.
John
Thank you,
Mike
