01-29-2018 09:24 AM
I’ve recently set up photoshop elements 15 on a new computer and can’t get print studio pro plugin to work.
The download works fine but it doesn’t show up in photoshop elements.
Here is what I got from system info:
Plug-ins that failed to load:
Canon Layout Plug-In for Print Studio Pro NO VERSION - - from the file “CNPSPPLayout”
Canon Print Studio Pro Export NO VERSION - - from the file “CNPSPP03”
Canon Print Studio Pro NO VERSION - - from the file “CNPSPP01”
PSP NO VERSION - - from the file “CNPSPP02”
Installed TWAIN devices: NON
Any help would be greatly appreciated, thank!
02-01-2018 04:30 PM
First off - thanks to everyone who took the time to help me out with this!
I FOUND THE ANSWER!!
I downloaded the latest Pro 100 printer driver from Canon and that solved the problem! After making that change I was able to get PSP to load as a plugin into PE 15, although it's listed twice along with another plugin that is greyed out.
I'll count this as a success!
01-29-2018 05:28 PM - edited 01-29-2018 05:35 PM
Are you trying to install Version 2.2.1?
Did you start PSE after installing it? PSP won’t install for PSE if it hasn’t been started.
If if you want to print 16-bit printing you need to install the XPS driver. First install the regular driver and then the XPS driver.
01-29-2018 06:35 PM
Yep I’m trying to installing the newest version.
i didn’t know that PE15 had to be open when I installed the plugin, I’ll try that first!
ill let ya know how it goes, thank you!
01-29-2018 06:49 PM
01-29-2018 09:12 PM
I thought that’s what you meant after I replied. Yes I had it open before I tied to add the plugin.
01-29-2018 09:14 PM
Did you try manually selecting the folder as discussed in the info for the download on the Canon site?
01-29-2018 10:59 PM
Not yet, I’ll try that as a last resort.
02-01-2018 04:30 PM
