12-11-2015 02:21 AM
I dont plan on keeping Canon in $$$$$$ by buying the color carts, rather ONLY the 3 BW carts for my Pixma Pro-100 once the "color runs out"
will this work fine?
remove DEAD colors when dry?
recommendations?
thanks.
I had planned on EVENTUALLY just using this as a professional BW printer for large prints.
12-11-2015 07:18 AM
Even when printing B&W there are small amounts of color ink being used. If you are only printing B&W then the amount of color ink used won't be great.
If you are interested in solely B&W for professional purchases there may be better printer options (i.e. pigment based inks)
12-11-2015 07:29 AM
well that REALLY sucks donkey logs.
There is NO logical reason one cannot ONLY use the BW carts. OTHER THAN Canon bleeding customers dry for INK $$$$$$
I used to work for Lexmark as a pro technician, and i know its ALL A GAME OF $$$ for INK, same goes for Canon too obviously.
easy way around that, ill NEVER give Canon cart. $$$$, ill only buy 3rd party and refills.
Touche' what a rotten stinker you are Canon.
12-14-2015 10:03 AM
It is not possibile to print the 256 grey-scale with a single black cartridge. A single black cartridge will print black. What about the other 255 shades? I suspect if you are printing a 0'0'0 page of text, you would use little to none of the other cartridges. But if it even has 0'0'1 in it ?
The only thing the printer can do with a single cartridge is, how much ink, the size of the dot and how far apart they are.
