12-19-2019 08:50 PM
My Pixma Pro 9000 Mark II printer will print a perfect test print, but when I try to print a simple 4 x 6 from Photoshop CC 2020 on my iMac running Mohave 10.14.6, I get the message "Stop printing of all jobs to this printer" and "Stopped -- 'Filter' failed, 1 page". Does this have something to do with the overflow reservoir? The printer has been idle for a while, but the ink tanks are fine and the nozzle check looks perfect. What's going on?
12-20-2019 05:27 PM
01-07-2020 08:38 AM
05-12-2020 02:29 PM
05-12-2020 02:48 PM - edited 05-12-2020 02:50 PM
You have to plug the printer in otherwise you can’t install the driver.
If you’ve installed the drivers from the Canon website at any point, then that could be why the message is showing up. That is why you have to delete the drivers from the /Library/Printers/Canon folder first, then remove the printer from Printers and Scanners and re-add it.
05-12-2020 03:57 PM
You are a GENIUS! Thank you!!! It PRINTED!!!
05-23-2022 05:47 PM
The official Canon drivers work now, and Apple is no longer providing printer drivers for the Pro 9000.
