10-27-2019 03:32 PM
Two days ago I had the full printer menu options in Print Settings when printing from Ps (Print, Printer: Canon PRO-100 Series selected, Clicking on Print Settings...), however now I only have Media & Qualilty, Layout, Paper Handing, Cover Page, Watermark, and Supply Levels, as if it were a generic printer. There's no area to select the type of paper, no Color Options. Page Processing, Paper Detailed Settings, etc. as in the full printer dialogue menu that I'm used to.
I'm running mac OS Catalinga (10.15), have the latest printer driver installed, and I did download a firmware update, however upon trying to open and install Printer Update Utility, I received the error "Cannot find the ROM that can be updated with this utility".
Any help is much appreciated.
10-31-2019 06:16 PM
Hey John,
Just following up - the culprit was when I re-added the printer via system preferences, below Name: (Canon PRO-1000 series) and Location: is Use: which should say Canon Pro Series. I went throught this step way to quickly as I've done it so many times, and accidentally left it at Airprint (the default). Sigh. At least it was an easy fix! Thanks for your contributions.
10-27-2019 06:48 PM
When you updated your driver and reinstalled the printer did you inadvertently install the AirPrint version?
10-30-2019 03:42 PM
Hi John, apologies for the delay, I just got back into town. No, I don't think that's the issue, I downloaded imagePROGRAF PRO-1000 series CUPS Printer Driver Ver.21.10.0.0 (Mac), and just redownloaded and installed it again to be sure. Still seeing the same problem after the reinstall, and I re added the printer via system settings.
10-30-2019 03:47 PM
Probably should give Canon a call at 1-800-OK-CANON.
10-31-2019 06:16 PM
Hey John,
