06-14-2021 09:43 AM
Does the age of the ink in a cartridge have an effect on a print?
06-14-2021 10:18 AM
Depending on conditions, it might.
What is more likely however is a partially clogged print head.
06-15-2021 09:14 AM
@aptillie wrote:Does the age of the ink in a cartridge have an effect on a print?
What problem are you having, or is this just a general question?
If a general question, Canon has stated that there is no expiration date for the Pro-100 inks.
But, as Rick said, not printing for a long time could result in ink drying out in the printhead and resulting in clogging.
06-15-2021 10:56 AM
This was just a gneral question. I have not used my Pro 100 in a while and just wanted to be sure ink was still good. I do not see any issues with prints and have not had any issues with clogging, but if I do, what would I see on my prints that woudl indicate clogging?
Thank you
John
06-15-2021 11:10 AM
Depending on the level of clogging you could see banding up to a complete loss of a color(s).
Just run a nozzle check and see how it looks.
Dye ink printers like the Pro-100 are more resistant to plugging than pigment ink printers.
06-15-2021 02:36 PM
Well I have'nt seen anything like what you are describing, so, so far so good!
Thank you again
John
