05-24-2020 10:15 PM
06-07-2020 06:58 PM
Here is where you would adjust image size in LR.
06-07-2020 07:00 PM - edited 06-07-2020 07:01 PM
@LaurenN wrote:These is the only Canon showing up. Do I need to download a different driver?
Yes. Go here and download the 1.06 version driver.
Turn off printer and unplug USB first.
06-07-2020 08:33 PM
Those changes worked...I now have the correct driver and set everything up the way you suggested. Should I be printing the calibration page again?
06-07-2020 08:40 PM
06-07-2020 08:46 PM
THAT WORKED. I want to eat the strawberries. 🙂
Now how do I get that to match with the drawings from the iPAD??
Thank you for working through this with me!!
06-07-2020 09:16 PM
06-10-2020 08:30 PM
Hi John,
We made the image a PDF and printed through Adobe Acrobat Reader, but the colors still don't match when they print, although they looked spot on in Reader. I also tried to adjust the settings through the Color Management options, but they all seem to be in order. I think part of the problem might be that with a laptop, when you change the angle of the screen, everything looks different, so I am not able to really tell if the settings are accurate. The brightness is set to its highest setting, which seems tolook best, but...?! I feel like I've followed all of the steps and am still coming up short, but I'm sure I'm missing something.
Any other tips? Thanks again.
06-10-2020 10:30 PM
06-11-2020 07:14 AM
06-11-2020 07:27 AM
Does this help?
https://kent.teamdynamix.com/TDClient/2005/Portal/KB/ArticleDet?ID=63342
