09-16-2021 11:53 AM
This started to happen after Apple updated MACs for security reasons. I re-installed the PPL software, resigned all my printers back in to no avail. PPL will print standalone and I can print from Photoshop but Photoshop refuses to pass an image on to PPL.
Computer : Mac(2013) "Trashcan"
OS is the very latest
Printers: Pro 1000, 2000 and 4000
PPL version 1.2.2
09-17-2021 11:40 AM
Maybe not clear enough. I bring an imgae up in Photoshop, use Automate to access PPL, PPL comes up with no image to print.
09-17-2021 12:38 PM
Maybe give Canon a call at 1-800-OK-CANON.
09-21-2021 12:42 PM
Seems that this is a known issue due to Apple's security update version 11.6 Big Sur. When PPL is started from PS, the image is not passed for printing and it locks up PS resulting in a force quit. Work around is to either print using the PS print engine or use PPL stand alone which works nicely for JPEG and TIFF files. Canon is working on the problem. Typical software update on Apples's part: fix one thing, break many others.
10-05-2021 10:30 AM
I'm also having this problem after updating to macOS Big Sur 11.6. I need to print for my business and I have seemed to have tried everything. Does Canon have a solution yet?
10-05-2021 11:23 AM
10-05-2021 11:40 AM
PPL does work well in stand alone. It actually works better when integrated into your workflow. I am a professional printer and can speak for Canon as with my last conversation with them, they said a fix is in the works. Use PPL stand alone for now and give it time. I think you'll like working with PPL better this way as this application is a memory hog but when used separately, you may go from Bridge and PS with ease. Let me know you thoughts as integration with PS may not be as important as you think.
Stephen
Canson Certified Print Lab #47
01-16-2022 09:59 AM
I have the same issue but with a twist. When I use Professional Print and Layout (PPL) as a stand alone application, it will only open the image file when I drag and drop, not when I initiate from the Open menu choice. I am running a new McBook Pro M1 on Monterey. I’m guessing the problem is due to security blocking but I have opened up permission for the program.
