07-06-2018 09:19 PM - edited 07-11-2018 12:33 AM
07-07-2018 09:44 AM
You might want to contact Moab. Platinum seems like a strange recommendation for a media type with texture. For the Pro-100 they recommend "Other Glossy Paper"
07-07-2018 04:19 PM
Sent an e-mail to them a few days ago.
It's odd that it is always in the same spot, it is almost like a paper handling problem when it gets to the trailing edge.
The rest of the print (and other prints without a back background) are flawless.
Any head height besides low reduces the resolution of the print too much for my purposes (high resolution digialt artwork).
07-11-2018 12:28 AM
Still no solution found which does not also reduce overall print quality.
07-11-2018 05:01 PM
See the February 27, 2017 post about Juniper paper on the Moab support forum.
07-13-2018 06:05 PM
According to jtoolman post in your DPReview thread its related to the fact that you are borderless printing. Apparently a warning pops up.
07-18-2018 01:43 PM - edited 07-18-2018 01:43 PM
No warning popped up in the print studio pro plugin that I was aware of, is this warning documented somewhere?... made many borderless prints at this size, just the dark ones with problems.
An interesting development.
Moab got the same band when they tried my PNG file on their printer, but when they used a smaller sheet of paper, the band did not appear to scale. Which means while it appears a particular type of image is causing it, it is not an artifact in that image (or it would have gotten smaller with the smaller paper).
They did not get the band with their other test files...
So, only possibilities left are some sort of hardware issue on multiple printers, or something in software is doing it.
10-31-2018 09:39 AM
Clean your print head's cyan port. Happens to me every once and a while. Cyan and/or blue seem to clog more frequently than any other tanks.
I've made over 1400 prints with my Pro 1000, seen it half a dozen times.
01-26-2023 02:14 PM
Did you ever find a solution to this issue? The images you posted show exactly the problem I am having, although I am not printing borderless. The band always appears just about an inch from the end of the paper. At present I am only doing test prints, and using only letter size paper.
Based on some vague wording in the manual, I believe this is a limitation of the printer hardware. The manual indicates that printing within 25mm of the end of the paper "can affect the print quality or the paper feed precision". I think the margin here is actually more like 30mm, but whatever.
I was attempting to find out from Canon tech support exactly what kind of degradation of the print quality we might expect, but I got nothing from them so far.
I do not believe this has anything to do with print head clogging since if it did, there would be problems all over the page, not just in one band near the edge.
So, can anyone confirm my hypothesis that this is a limitation of the printer? (one that they don't really want to talk about)
