PIXMA Pro9000 Mark II Trouble Setting Up on Windows 10
Sue8
Hello. I am hoping someone might be able to help. I just purchased a slightly used pixma pro 9000 mark ii. I have spent a long time trying to connect it to my PC, which uses Windows 10 Pro. I tried with the disk that came with the printer as well as downloading the drivers from the Canon website. I have uninstalled and re-tried several times. I have tried drivers for Windows 8.1 but that did not work either. I have turned it off and on, changed USB cables, etc. but nothing works. It does say, "Printer detected...please wait...etc." at first but eventually says, "not detected..check connection..." Any suggestions? One person on a forum said it worked only when he switched to a very short 6" USB cable. Could this be the problem?
Thank you!
8 REPLIES 8
jrhoffman75
Support | Support - Professional Inkjet Printers | PIXMA Pro9000 Mark II | Canon USA
Verify that you downloaded the correct drivers from here.
Turn printer off and unplug USB cable from computer.
Uninstall any Pro-9000 software that show in the Programs & Features page of Control Panel.
Remove any Pro-9000 printers that might show in Devices & printers page of Control Panel.
Install the 2.75 driver.
The install process should say to connect the printer to the computer and power it on.
If the connection error appears unplug USB and try another port on computer.
Are you using the USB cable that came with the printer?
Thanks for your reply. I did do all of those things multiple times. I purchased the printer from craigslist. It looks brand new. It did not come with the cable so I used my own. I have several and tried a few but it still does not work. Could you please tell me the length of the original cable that came with the printer?
Thanks!
jrhoffman75
I don’t have that printer. According to the Canon website it doesn’t look like it comes with a cable. A six inch cable doesn’t sound realistic.
Are you sure it was functional when purchased?
It was sold as functional but I really have no idea. It turns on and the head moves properly...everything looks fine. When I connect it to the USB port, the computer makes a sound ..so the connection is good. You are right, a 6" cable does not seem realistic lol  but I have ordered one anyway and will try....someone said Canon told them it should be 10" maximum which also sounds nuts
Just to be sure - you are using a cable that looks something like this?
Yes, it is the same type of cable I used to connect all printers in the past. Maybe I should try to replace the OS with windows XP or Vista and see if that helps? Otherwise, I am not sure what to do
A different OS should separate a computer problem from a printer problem.
I’m not sure it would be wise from a security aspect if the computer is connected to the internet and has sensitive personal data on it.
Thanks!   Well, I ended up getting an adapter and I connected the printer to my laptop instead of the desktop, to see if that would work. My laptop is also Windows 10 pro but for some reason, it worked. However, now it is giving me a printhead error!  ughhh
03/28/2023: New firmware version 1.0.3.1 is available for EOS-R5 C
03/14/2023: New firmware version 1.8.1 is available for EOS R6
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.0
01/18/2023: New firmware version 1.1.1 is available for EOS R6 Mark II
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
