06-21-2021 08:24 PM
I purchased a used pro 200 and am unable to get the print head alignrment too to work . I will not allow me to to a manual alignment .
Oh so frustrated
the heads are not clogged , I removed the print head and reset it , ink levels are all ok
Please help
Thanks
06-22-2021 10:47 AM - edited 06-22-2021 10:54 AM
Here is what I found:
Canon Knowledge Base - Support Code 2500 Appears (Automatic Print Head Alignment Failed) - PRO-200
Did the printer ever work properly?
Or is this what you experienced the first time you tried to use it? You may want to contact the seller.
06-22-2021 11:43 AM
thanks so much for your response . I spent some time this AM with a Canon Tech who was extremely helpfull and after several tests , as a courtesy , is sending me out a new print head . Hopefully this will solve the problem .
This is the first time after many ebay purchases that I have received an item which did not functiion as described .
I have sent messages to the seller with no response to date
once again thanks
Dan Doyle
06-29-2021 02:20 PM
I spoke with customer service and was informed that the print head was back ordered .
Have no idea as to when it will be available
Dan Doyle
07-23-2021 04:11 PM
the same thing happened to me and after rewading your post I called today to see that the print head that I was going to be sent was on backorder too. I wonder if I purchased a lemon and if I should try and return the whole machine for a new one. Good luck.
07-23-2021 04:52 PM
Actually the print head only too about 4 days for me receive
07-23-2021 04:56 PM
Now for the update . The print head dis not fix the problem . When I conveyed the problem still existed Canon offered me a replacement printer as minw was under warantee . It took about a week to receive the new one which is up and running with no problems .
Canon customer service has been nothing but professional throughout this entire process .
They stans behind their products and are a truly rare exception to what I have experienced with some other countries
Thank you Canon
07-23-2021 05:05 PM
Ohh awesome thank you so much for the reply too. I just called them as well and was able to cancel the print head being mailed out and switching this machine for a new one. It's nice to know that that didn't fix your issue, because I felt bad asking for a new printer lol. And I agree too is was shock talking to kind happy people wanting to help me with my issue.
Thanks for the reply and happy printing!
