07-23-2023
01:03 PM
10:12 AM
Hello,
I'm trying to print a 5 x 7 image on 8 1/2 x 11 paper. The image is in Lightroom 6.14 and the printer is a Pro-200. Lightroom offers a max size of 4 x 6, yet the image comes out as 4" square. I exported to my desktop (OS Catalina) and used the standard print option, but it prints only part of the image. I can print on 5 x 7 paper but I may want to trim with a larger border. Thanks for any help. DG
07-25-2023 01:11 PM
When you added the PRO-200 onto your Mac, make sure it's using the Canon driver and not Airprint. If you only get the Airprint option, click HERE and download the PRO-200 CUPS Printer Driver Ver.24.30.0.0.
07-25-2023 01:11 PM
07-25-2023 04:35 PM
Thank you, Arthur. I've downloaded most of the software shown on that site and will see if that does the trick.
07-25-2023 05:28 PM
Thanks again for your help, Arthur. Now I have another problem if you don't mind. I'm trying to install Print Studio Pro as an extension to Lightroom 6.14. When I click Plug-in Install, the box shows Lightroom found, would I like to install? I click yes and the next box says a required file is not found, but it doesn't indicate which file. Is there a way to solve this mystery? David
07-26-2023 01:38 PM
While the Print Studio Pro plugin is not available to download for this model printer, I would recommend the Professional Print & Layout Ver.1.3.6 file. This file can be downloaded from the same page you downloaded the CUPS printer driver.
For more information about Professional Print & Layout, please click HERE.
07-26-2023 01:57 PM
I'm so glad I asked, so I can stop trying to install it. I have downloaded Pro Print & Layout and will give that a try. Many thanks again, Arthur. You've made my day and week! My best, David.
