06-21-2026
10:24 PM
12:05 AM
StevenMOD
I've had this printer only a couple years. I tried to print something last night and the paper just comes out blank. I have used the gear screen to clean it and then also did the deep cleaning. But still nothing. Ink levels are okay and paper in loaded correctly. Don't know why it just stopped printing my documents
06-22-2026 09:20 AM
Frist thing to do is determine if this is caused by the printer itself or a software issue. Print a nozzle check, it will let you know if you have an ink delivery, or printhead problem. If it prints correctly then it may be a software issue.
To perform a nozzle check on the PIXMA TS6120, turn on the printer, load A4 or Letter size paper, then press the "Home" button, select "Setup," choose "Maintenance," and finally select "Nozzle Check." Follow the on-screen instructions to complete the process.
