PIXMA PRO-200 Inaccurate Colour
Popito
Struggling with my new canon pixma 200 printer. chose this as it handles 300gsm card stock and quality of print.
I'm not getting a colour rich enough print as compared with my old HP printer. I'm using same quality card but seem unable to adjust colour management to produce the quality print I need.I'm a colour pencil artist and need my work to print true to colour and definition. The image below on left is what I need to achieve, image on right is what my pixma is producing. Any help would be really appreciated. \thanks
8 REPLIES 8
Mike
Moderator
Moderator
Hi Popito,
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what program you are using to print from as well as the operating system/version on your computer. Any other details you'd like to give will only help the Community better understand your issue.
Windows 10
using canon installation software
jrhoffman75
What software are you printing the image from?
Windows 10
canon pro software
Sorry. I do not know what this software is. Can’t assist.
ebiggs1
The number one reason why prints come out not looking good is a misadjusted monitor. If you can't see the correct image on your monitor how do you think you can print it? You see the printer does not take info from the monitor to make the print. So if the monitor isn't showing you exactly what the print will look like you get poor results.
You can d/l test prints and you can check the print head.to make sure the printer is working properly.
Printing the Nozzle Check Pattern
  1. Check that printer is turned on.
  2. Load a sheet of A4 or Letter-sized plain paper in the top feed. Loading Paper in the Top Feed.
  3. Select Maintenance on HOME screen. LCD and Operation Panel. ...
  4. Select Nozzle Check. ...
  5. Select Yes. ...
  6. Examine the nozzle check pattern
Windows 10
  1. From the Start menu, select Settings.
  2. Select Devices.
  3. Select Bluetooth & devices.
  4. Select Devices and printers on the right.
  5. Right-click on the corresponding printer driver icon.
  6. Select Printer Properties from the pop-up menu.
  7. Select the Print Test Page button.
EOS 1DX and many lenses.
Thanks, done all that
ebiggs1
Call Canon support 1 (800) 652-2666
