08-20-2022
10:32 AM
12:00 PM
What is the procedure to remove the cover from the pixma pro-200 printer? the print head holder has nylon guides that have fallen off due to improper shipping.
08-20-2022 11:07 AM
Is it a new printer? Return to sender as defective product?
08-20-2022 11:51 AM
not new..has about 30 pages use.. my fault, transported without taping down print head and looks like it got upside down. I think I can fix if I can get the cover off
08-20-2022 12:07 PM
Give canon a call at 1-800-OK-CANON and see if they can assist.
08-20-2022 12:52 PM
appears that canon only gives support during normal (M-F) hours... try again on monday am...
08-22-2022 09:21 AM
Called canon tech support, the printer is out of warranty so a replacement is not available. The tech gave me the number for the "upgrade program", called this am and found out that the cost is list minus 10% plus tax, shipping is free and I don't have to return the printer. So, bottom line.. still looking for how to remove the cover, i really think I can fix it if I can get the cover off,,, anybody know how that is done?
04-25-2023 03:20 PM
Hi, Wondering if you were able tog figure this out? Have the same exact issue and seems like it would be simple to put plastic piece back in place with some info. Please let me know, Thank you
04-25-2023 03:49 PM
no solution, ended up simply buying another pixma-200 printer from best buy...
04-29-2023 02:48 PM
Thank you for the quick reply. It's sad to see good printers go to waste over a minor repair that could likely be done with some info. Im thinking of trying to just tinker with it. Did you attempt to disassemble it at all or end up having to just dispose of it. Thank you again
04-29-2023 04:54 PM
ended up disposing of it... bought a new one
