How to set Avoid Paper Abrasion when using Professional Print and Layout software
amv8
Hello:
I'm using the Pro-1000 printer and usually print through the Professional Print and Layout (PP&L) software on MacOS either as a plug-in to PS or as a standalone application.  There are a number of printer settings that can't be controlled through Professional Print and Layout, but can from the standard print driver, for example, "Avoid Paper Abrasion."  How can I set Avoid Paper Abrasion when using the PP&L application?  Can I set it using the menu on the printer and the printer will just retain it unless it is changed again on the printer or changed via the print driver?
10 REPLIES 10
@jrhoffman75 wrote:
That is strange for PP&L, since it is possible in PSP. But it is a convoluted process.
Thanks!  Yes, that's a convoluted process, but it appears to work with PP&L too!
