‎10-25-2019 09:31 PM
I'm trying to remove or replace paper types I've registered in Print Studio Pro and I can't find any way to do that. If I save a setting with an existing name to overrwrite it, it just says you can't do that, the name already exists, but there seems to be no way to update or remove a registered paper type.
‎10-27-2019 10:36 AM
Select "Add from Print History". Then you can delete.
‎10-27-2019 09:11 PM
Thanks. That worked. I appreciate the answer.
Do you know of a way to change the settings in those presets? Or are you stuck with it once you do it.
‎10-27-2019 10:21 PM
I think you just create a new one.
