01-05-2014 10:16 AM
How do I print a photo with equal margins? I am using Mac OS X 10.8.5, Lightroom 4.4, and Canon Print Studio Pro 1.3.0. For both of these programs, when I adjust the slider for one side the margin for the other side will also change. This happens with all paper sizes. I want the margins to be equal.
Thanks for your help.
01-05-2014 06:38 PM
Tinman,
You can print equal borders with either Lithroom or the Print Studio Plugin. It is however import to set the proper cropping within Lightroom for the photograph and the targeted medium.
For a 0.200" border around an image for a 4"x6" print, crop to 3.6"x5.6" and set the border with Print Studio Pro plugin to 0.2, also set to center the image.
It has been working great for me.
Hope this helps.
Brian
01-05-2014 04:35 PM - edited 01-05-2014 04:35 PM
You mean you want the white boarder equal all the way around your photo?
That will depend not only the margins you select but the print size and the paper it is printed on.
You can add a stroke (LR) around a print and use a paper trimmer.
01-05-2014 05:33 PM
Yes.
I have tried on 4x6, 5x7, 8x10, 8.5x11, and 13x19, paper and I have selected the print size to match the paper size.
Is there a way to have equal margins without trimming?
01-05-2014 06:38 PM
Tinman,
Hope this helps.
Brian
01-05-2014 06:54 PM
Thanks for the reply, I am going to try it out now.
