09-10-2015 09:36 AM
When ever I try to printing photographs on the Canon pro 100 printer using an ICC profile and software color management I get prints with a magenta color cast. I believe this is due to double color managemant?
If I set the software to allow the printer to manage colors the colors are OK but I need to increase the pring brightness and the prints on the standard settings are mush too dark.
How can I print from Lightroom and Photoshop using an ICC profile for my paper and not have the problem of the color cast inb the prints.
I ca't find anywhere to turn off color management in the printer set up.
I am using Lightroom CC, Photoshop CC on an IMAC computer and Canon Pro 100 printer. My computer display has been calibrated using a Spyder 4 and screen brightness has been turned down to a level recommended for photopraph processing.
Thanks
09-10-2015 01:56 PM
If you add IJ Network printer you will get a printer setting window like this and just work through the dropdowns to select your options.
Then choose paper type and settings in Lightroom.
09-10-2015 02:01 PM
Using PSP
09-10-2015 01:41 PM
On the Mac you don't get the option. Be sure you have added the printer in System Preferences using the IJ printer version, not the Bonjour version.
I am working on my PC now, but I will get on my MacBook and see if I can get some screen shots.
The other thing I recommend is starting out using Canon Print Studio Pro. That takes care of all the settings so you can at least besure everythig is working OK.
09-10-2015 01:56 PM
09-10-2015 02:01 PM
Using PSP
09-11-2015 02:24 PM
Thanks for the reply.
After much searching it looks like the printer was set up om Bonjour.so I have deleted the printer and reinstalled using the IJ setting.
Things look much better now.
Thanks again
09-11-2015 02:38 PM
Good news. Mac is a pain as far as high performance printers go. It's not enough to install the driver. Then you have to add the printer and be sure than Bonjour isn't selected.
