12-04-2018 09:50 PM
After operating without any issues for 3 years my Canon Pro100 started printing very badly -- colors not correct, colors washed out, no contrast or sharpness of any kind -- I changed the ink tanks even some not needing changing -- ran all cleaning utilities (twice) and the test pages printed correctly -- prints are still all washed out and not correct
UsIng a MacBook Pro with High Sierra -- note printer communicates correctly for color prints with my HP All-in-One.
Any similar experiences or thoughts on a solution. Thank You
Regards
Terry D.
12-05-2018 11:34 AM
Hi tjdonofrio,
The sequence you listed is the best way to remove and reinstall the printer.
As far as connecting with a USB, that is really up to to you. If you only print from the one device and dont need to print wirelessly from other devices then I would recommend connecting the printer with the USB cord.
12-05-2018 08:48 AM
Did you make any changes to your MacBook?
Try reinstalling the Canon driver and be sure you are selecting the IJ Series version of the printer, not the AirPrint version.
12-05-2018 08:55 AM
Thanks
I did reinstall the latest drivers already -- will check on the versions I am installing and try again. No changes to Mac since High Sierra update.
Thanks Again
Terry
12-05-2018 08:59 AM
One more update -- the problem occurs on both versions of the printer. Before I scrap this printer and get another Pro 100 (rebate until the end of year), I may try reinstalling the software.
Thanks Again
Terry
12-05-2018 09:02 AM
You want to see this info, but it does sound like a bad unit.
12-05-2018 09:26 AM
Continued Thanks
Terry
12-05-2018 09:30 AM
My similar screen says 2.0 for Driver Version ???
I guess I better definitely download new drivers.
Thanks
Terry
12-05-2018 09:32 AM
Do you have a good link you use for the latest Canon Printer Drivers ?
Thanks
Terry
12-05-2018 09:35 AM
You might want to also delete the existing printer and re-add when you download new driver. Wait a few minutes for the Canon version to appear when you click "+"; the AirPrint/Bonjour driver usually appears first.
12-05-2018 09:37 AM
My mistake
When I go to the non airprint version of the printer it says 16.20.0.0.
I should be OK
Terry
