01-07-2025 08:22 PM - last edited on 01-07-2025 09:30 PM by Tiffany
Hi Everyone, I recently bought the Canon PRO-200 printer and I am generally satisfied with the quality of prints, I amhaving problems with b+w prints. The all have a blueish or reddish tone to it. I played with the color settings but the problem persists. Does anyone have any suggestions ?
Thank you
01-07-2025 10:50 PM
It sounds like you're experiencing a common issue with the Canon PRO-200 when printing black and white (B&W) images – color casts (bluish or reddish tones). Here are a few suggestions to help you get true neutral B&W prints:
If you're printing from software like Photoshop or Lightroom, install and use Canon's Print Studio Pro. This plugin often provides better color management and more accurate B&W print options.
When printing, ensure you select the Grayscale or Black and White mode in the printer driver settings. This bypasses some of the color adjustments that may introduce unwanted tints.
In your editing software (Photoshop, Lightroom, etc.), set the Color Handling to "Photoshop Manages Colors" (or similar). In the Canon driver, set "Color Matching" to None or "Off." This prevents double color management, which can cause tinting.
If you're using fine art paper, the “Fine Art” setting in the printer driver may cause slight color casts. Try using the Standard Paper setting with custom ICC profiles to see if the problem persists.
Ensure your monitor is calibrated correctly. A monitor with an inaccurate color display can lead to unexpected print results.
Try printing the same image using different software (Lightroom, Photoshop, Professional Print & Layout, etc) to rule out software-specific issues.
01-07-2025 10:56 PM
To reset your Canon Pixma Pro 200 printer to factory settings, follow these steps:
Turn on the Printer:
Make sure your printer is powered on.
Access the Menu:
Navigate to Reset Settings:
Choose Reset Option:
Confirm the Reset:
Restart the Printer:
After resetting, reconfigure your printer, reconnect it to your network, and reinstall drivers if necessary. This should help clear up any configuration issues.
01-08-2025 08:38 AM
Thank you
The type of lighting you are viewing with can also cause a color cast with monochrome prints on some papers.
