09-10-2019 08:08 PM
Hi All,
Wondering if anyone ran into this same issue? I was able to print 13x19, 5x7, but I don't seem to be able to print to 4x6. Every time I tried to print to 4x6 I would run into "paper jam" error. I have tried practically everything, from using the rear tray which I don't believe is designed for 4x6 paper. The top-loading seems to have problems with handling 4x6 papers. It would feed halfway and then jam.
For the record, what paper size would you be using with the rear feeder (i.e. the doors at the back of the printer)?
Thank you,
LV
09-09-2022 01:15 PM
Also make sure the paper size is correct - the printer keeps defaulting to letter.
08-12-2023 05:09 PM
OMG I was having this issue for a year and only had few chances to successfully print out 4*6. Thank you so much for the info. I thought it was my printer getting old.
03-08-2024 11:52 AM
Thank you for posting this !!! I did a Google search for printing on 4x6 paper. Doing the cleaning now. Thank you sooo much !! Let the scrapbooking begin !!! - Kate
