01-03-2022 08:15 PM - edited 01-03-2022 08:30 PM
I upgraded to a new Dell XPS Windows 10 computer. When I try and run the driver (PRO-100 series XPS Printer Driver Ver.5.87 (Windows)) I keep getting this message:
No IJ printer driver is correctly installed. Install the driver correctly so that printing can be executed... blah blah
I've tried repeatedly, turned off Windows' driver safety feature, run 'find new devices', nothing works. I'm using a direct connection (USB) because wifi can't handle huge photoshop files.
There's nothing wrong with the computer or Windows. I've installed every other device including a laser printer with no problems, only the Pixma 100. Help!
Thanks,
Ed
Windows 10 pro up to date, Canon Pixma 100 printer. The printer worked perfectly on my old desktop.
01-04-2022 12:01 PM
Ok, I'll try that, thanks. But I didn't see any option for drivers at all, much less 8/16. Where can I find it?
01-04-2022 09:02 AM
Greetings Ed,
You need to install the standard 8 bit driver first, then you can install the 16 bit XPS driver. It works more like an overlay.
Support | Professional Inkjet Printers | PIXMA PRO-100 | Canon USA
01-04-2022 12:01 PM
01-04-2022 12:49 PM
Found it. Website is poorly labeled, though, it defaults to the 16 bit. Had to dig to find the 8 bit which is not labeled as such.
Thanks for your help.
01-04-2022 12:51 PM
Click the link I posed above.
01-04-2022 01:16 PM
One more question: the driver package (working well now, thanks) doesn't have the utilities with it, specifically the ink levels. Is that available in another file?
01-08-2022 11:20 AM
It's not a separate utility. It will display when the printer is printing a file.
You can download "My Printer" app from Canon and use that as well. It's the Printer Status button.
01-08-2022 12:59 PM
Thanks for the replies. All is well.
