11-01-2021 03:03 PM
11-03-2021 08:22 PM
11-03-2021 10:27 PM
11-03-2021 10:42 PM
11-03-2021 10:43 PM
11-03-2021 11:02 PM
11-04-2021 05:53 AM
@christinamsart wrote:
Yes, I just figured maybe it would be simpler to have print studio pro because I don’t have much experience with photoshop. I’ve been able to make art prints look good after like 20 wasted trail sheets and adjusting colors A LOT. Is there a way to calibrate my monitor to my printer? I noticed my prints come out looking very dark and desaturated. I have to adjust the brightness higher, contrast and saturation before I get something that even looks similar to the original.
Let's try and get this sorted out for you.
I am going to assume that since you worked with Canon they verified that you have the correct driver installed.
If you haven't run a nozzle check you should do so just to be sure that all cartridges are printing correctly.
Download the test image from this link: https://1drv.ms/u/s!ApNpngg2Z6dbhIYEVaNQBuYp2nUaWg?e=s2DPAa
It is a calibrated standardized image that many folks use to verify proper printer performance.
Open the image in Photoshop. Do not make any editing adjustments, regardless of how the image may look on your monitor.
I recommend that you always print by having Photoshop manage color. That was it doesn't matter if you use Canon paper or third party papers. You just select the proper Canon media type and the ICC profile for the paper you are using.
Configure the Ps print window like this:
When you select the button I have labeled "1" the Canon printer driver will open. Configure the driver as shown below, following steps 1 through 5.
Then, back in Ps, select your ICC profile in "2".
Now print your test image.
If your printer is working properly you should have a proper image with good brightness and color. If not, there is a printer problem we need to address.
If you have a good print then you need to compare it to your monitor. They will never be exactly the same since the monitor is a back-projected image and the print is reflected light, but they should be very close.
A frequent complaint that "my prints are too dark" is really caused by the monitor being to bright. The person reduces the exposure of the file and then when it prints the image is too dark.
What kind of monitor do you have? Does it have various setting like Internet, sRGB ?
Come back after you have made your print.
11-15-2021 04:16 PM
What version of Ps are you using? I noticed that the PSP plugin under Automate does not show up in the latest version of Ps. I haven't seen it work since version 21.
11-15-2021 04:24 PM
@draughonc wrote:What version of Ps are you using? I noticed that the PSP plugin under Automate does not show up in the latest version of Ps. I haven't seen it work since version 21.
Windows version 23.0.1
11-15-2021 04:27 PM
11-15-2021 04:58 PM
Sorry about that. I'm having trouble with Professional Print and Layout not loading Automate. I may have indicated the wrong folder when prompted.
