04-15-2022
01:08 AM
09:07 AM
James_C
Hi there, I just got my new pro 200 and trying to calibrate the print. It’s much darker in brightness and color is darker also. I’m using the ppl and try hard proofing and still unable to much color. Please help
01-21-2024 10:44 PM
My aging brain forgot. I've already been told that the International Paper cardstock I have is uncoated.
Is there any chance someone knows if there is an ICC profile for the cardstock I have?
thanks
baumgrenze
01-22-2024 05:34 AM
Maybe try the Printer forum over at dpreview.com
03-31-2024 09:05 AM
Hello,
I am setting up the PRO-200 for my mom with her Mac. We are seeing the issues where the colors on the screen do not match the printer on photo paper or card stock. I see your recommendations above, but there are no screen shots visible. Can you repost the settings?
It is too bad Canon does not make this work out of the box for Mac. We were hoping with a Studio Display and this professional printer there would be no issues.
Thanks for your help!
Peter Geremia
Ps. We tried Printer Managed, ColorSync etc. We made sure we choose the correct paper. We did load the proper driver etc. This is running on macOS Sonoma.
03-31-2024 09:42 AM
1. Make sure you have a good nozzle check.
2. Even if you have installed the Canon driver be sure that the added printer is not the AirPrint version v
3. Print the test image, following the directions.
4. Report back what the results are.
03-31-2024 08:58 PM
Ok.. nozzle check was good.
I have attached 3 prints.
The test image print photo. which looks pretty close to me.
Then I printed the a background color that is different on screen and printed. I cropped the image due to privacy.
Let me know your thoughts.
Thank You,
Pete
03-31-2024 08:59 PM
I thought the file names would show. The LEFT print is SCREEN original. The RIGHT print is photo of printed image.
03-31-2024 10:23 PM
That’s not a good result for the test image. Can you post screenshot of nozzle check?
What operating system?
What software?
03-31-2024 10:25 PM
I just saw on earlier post you said Sonoma
Have you verified that you aren’t using the AirPrint driver?
04-01-2024 08:32 AM
I need to go over tonight and collect all of the settings. There are a lot of knobs to turn for adjustment. Maybe you could help me with exactly what settings to use for Display and Printer and Photoshop? I tried ColorSync and Printer managed color. I also loaded the programs they provide and it was a bit better but not a lot.
I will do the nozzle check again and get pictures of that.
Is there a documented process somewhere getting an Apple Studio Display color matched with this printer exactly? I cant imagine there isn't anything? Just have not been able to find yet.
I will get back to you tonight.
Thank you for your help.
Pete
04-01-2024 08:42 AM
I work from Lightroom, but I suspect Ps would be similar. I always choose Printer Manages Colir and choose the ICC profile, even for Canon paper.
Are you opening the test image and printing without making any adjustments?
canon has a free software Professional Print & Layout that is a plugin for Ps or LrC. Sets all the correct “switches” for printing.
