calibrate pixma pro 200
lauraF
I am unable to get this thing to print even remotely correct.  I have printed a calibration image and it is clearly quite off. the blacks are all solid black, no squares, same with whites.  I have gone through surreal amounts of paper and ink and always run two pattern prints, first one for B & C, second for color.  I set colors and the final print is not a match to the test print.  its just always crazy over intense.  I even installed a new operating system on my computer, which has hrd.  I can't make heads or tails of the canon instructions for calibrating, there is no "utility" or calibration on my control panel.  I am using PPL.  I've spent countless hours on this printer nightmare.
3 REPLIES 3
lauraF
I'm replying to my own post.  I have ordered a BenQ 99%sRGB monitor and Spyder4Pro.  Let's see how that goes! I didn't have a clue about "calibrating my work flow for print" but I get it now -fingers crossed. I don't doubt the quality of the printer - just my learning curve has been impossible, maybe till now....
jrhoffman75
Welcome. I will try to assist.
Here are a few things to try (if you already haven't).
1. be sure you are getting a correct nozzle check pattern.
2. ensure you are using the correct printer driver. If you are using a Mac computer be sure you are using the Canon IJ Series driver and not the Apple AirPrint driver.
3.Download and open this test image in your photo application: PrinterEvaluationImage_V002_ProPhoto.tif. Do not make any adjustments, regardless of how the image might look on screen. Just select the printer settings and print.
4. If the printer is functioning properly you should get a perfect image. Here is the background material for the image: Printing Insights #49
Let me know how that works.
Yes, the printer is functioning perfectly.  It's a "workflow" problem that I am just now becoming aware of as a potential cause of 3 years of frustration.  Shifted from laptop to adobe RGB monitor, upgraded scanner, and invested in a used Spyder4Pro.  The test image was informative, appears that knocking contrast down to -15 will solve the majority of my difficulties.  Fingers crossed Thank you for your help
