03-29-2025
06:44 PM
07:51 AM
James_C
Printing in plain / normal paper with the TM-350 there is a weird behavior not present in a TX-4000.
When I select media type: plain paper, if print priority is images everything is fine, grays are aceptabilly neutral.
But if I select Print priority : line drawing/text a bluish greenesh tint appear on grays
How can I overcome this? I need the 600 dpi resolution line drawing/text provide with the gray neutrality of Image print priority.
Makes sense? In TX4000 is totally posible but not in TM-350. Why?
04-01-2025 03:40 PM
Hi estebani,
Please contact technical support via phone for further assistance. There is no charge for this call. Please dial 1-800-423-2366, Monday-Friday 9:00 am to 6:00 pm Eastern Time, excluding holidays. A Technical Support Representative will be able to assist you with your imagePROGRAF TM-350.
05-19-2025 05:29 PM
Anybody knows if a custom paper type can be created that use plain paper as base paper, an use the color profile of image print priority, but the speed and 600 dpi resolution of line drawing/txt print priority?Thanks.
