11-04-2022 10:37 AM
I had to revert to Photoshop 2022 to be able to use the iPF6400_8400_9400Series-PinPD-MacX-603 plugin for Photoshop. Could you please let me know when you will have updated the plugin for PS 2023
Cheers,
Ralf
06-19-2023 09:10 AM
Hi Philip, I’m tagging you in this reply to make sure you see the workaround that worked for me. I described it in detail below, but I enabled Photoshop to open with Rosetta and then the plug-in showed up. Hopefully that will work for you as well.
06-19-2023 10:58 AM
Excellent. But we should still have an upgrade of the software so we don't have to go back and forth between Rosetta and the latest OS (using Rosetta slows down the rest of your system so you don't want to keep your computer on it.)
06-19-2023 11:21 AM
Absolutely! Maybe Canon will soon get this fixed.
07-28-2023 09:46 PM
I'm having the same issue. I had to create a separate Volume for Big Sur, 2022 and 6.03 plugin to get it to work. With Ventura, as soon as you launch the plugin, CRASH. The printer is a great printer but now I'm wondering if I would ever buy another Canon if this is the way they roll with software. Sad.
07-28-2023 09:47 PM
That hasn't been my experience. Ventura seems to be the culprit with 2022, 2023, beta. It does not matter which PS version. It is the 6.03 plugin that's at fault, at least for me.
07-28-2023 09:49 PM
Do you think I should install Rosetta 2 even though I have an Intel based iMac? Thanks!
11-30-2023 08:01 PM
Hi Glenna,
do you know if there is a way to print with the 8400 without the **bleep** print plugin? My Epson 9900 is just as old as the Canon 8400 and it doesn't need any plugin, just the driver. I tried the Canon the same way but the colours and density are way off.
Cheers, Ralf
