06-05-2024 03:22 PM
Hello,
We have had our Canon Arizona 1360 GT for around a year and a half. From the very beginning, we have had difficulties with the ink. We were set up with the Glossy ink, then 5 months later, we switched to matte ink. This did help, but we continued to find ink was still chipping on the edges of graphics, mostly on certain colors. Red is a HUGE issue with chipping.
We have worked with Canon Illinois and had benchmarks done. Still, chipping seems to be an issue. We have done a lot of work on our end to get it to where we want it.
At this point, we were thinking of hiring an analyst, but I wanted to reach out and see if anyone has had this issue. Any advice would be greatly appreciated!
08-01-2024 04:54 PM
Hi vhomuth,
We have the same printer. Lately I had noticed Red also being prone to chipping. I don't have a solution unfortunately. We are starting to dive into it. Checking the UV lamps for proper curing, making sure material is meant for digital printing, and looking to try some AP (adhesion promoters).
If you have any updates I would love to know!
04-04-2025 04:17 PM
Unfortunately no, and now I am seeing the red ink is chipping on more than just edges now.
I guarantee it is the ink formula. Adhesion to several surfaces have not been issues with the past printers, but with the 1360 GT, I am finding this is the biggest issue.
Did you find the adhesion promoter worked? Have you tried it?
04-07-2025 09:27 AM
I have tested both Adhesion Promoters - AP2155 and 3155. Our testing was done on Acrylic - White Opaque Plex (3015)
AP3155 has the strongest bond but has an extremely potent smell. Worth the strength of the adhesion though.
Get a spray bottle, spray it on, wipe in the direction of the print head with some poly wipes to spread evenly. Good to print right after. Sometimes in full images you may see the wiping motion left behind, so avoid any flat colors and keep a lot of movement in photos. I'm still trying to figure out how else to apply it. Both of these Adhesion Promoters are not nearly as expensive as "Mean Green" and "Red Hot" and a little goes a long way. Still on my first bottle.
We use a white ink option as well. Ran multiple tests doing WCV (White, Color, Varnish), CCV (Color, Color, Varnish), CV, and also a W,WCV (Extra white file before).
Using both AP's helped with adhesion, but using white ink made the adhesion worse on all tests. White ink is thicker naturally and makes me think it leads to chipping.
I'm assuming you are using the IJC357 Ink as well?
Hope any of the info I gave helped. Haven't had any chipping issues since using the AP.
